주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Volume button not working
Volume button are not working while pressing it
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 10
댓글 13개
How to change volume button
의 공유
@abhijitdebnath Does the existing answer not answer your question? If not, what's different about your question from the original?
의 공유
Volume button repair
의 공유
@abhi31782 See the Most Helpful Answer below; your issue has already been addressed.
의 공유
My volume button not working
의 공유
댓글 8개 더보기
댓글 달기
답변 3개
가장 유용한 답변
이미지 내용 보기:
이미지
이 답변이 도움이 되었나요?
점수 4
댓글 2개:
Kam karne Wala volume
button Kam nahin kar raha hai
의 공유
댓글 달기
@pranav55998 could most certainly be a bad volume button flex. To replace this and since iFixit does not yet have a guide for that, use the one from here It is written in Spanish so use a browser that does the translating for you, if needed. The volume button flex is readily available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Well check for any sort of physical damage near the volume button area if recently your phone is drop down so that can also cause the damage on the button and also check for the latest software version update sometime an outdated software version can also cause these kind of issue as well.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Pranav 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 15
지난 30일: 46
전체 시간: 1,754
