주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo G50-70은 바닥면에 인쇄된 모델 정보(모델명 20351) 또는 트랙패드 옆의 스티커를 통해 식별할 수 있습니다. 이 노트북은 Dolby 오디오를 탑재한 15.6인치 화면을 갖추고 있습니다. 2014년부터 제조되었습니다.
Blue screen error code 0xc0000034
Hello!
Please could someone help me. 🙏🏻
My old Lenovo G50-70 has just presented me with the blue screen of death: error code 0xc0000034.
At the time, I was looking at a saved word document, the screen became pale and at the top it said that Word was not responding. I could not escape this frozen screen, so I powered off.
Upon powering up, the lovely blue screen of death appeared.
Following YouTube advice, I have tried powering up and off 3 times. Nope, doesn't work.
I have tried powering up whilst holding the F8 key continually. Nope.
Same with F11 key. Nope.
I think I have Windows 8. I know, I know, ancient.
Look, the problem is that I have lots of saved files that I need on this laptop. I do have a new laptop, an Asus Vivobook, and I was about to transfer files from Lenovo to Asus, when this disaster struck!
I am a yoga teacher, I am not technically savvy with computer systems.
Please, please, could someone help me. I just need it to work long enough for me to transfer my saved files and class photos etc., on to my new Asus.
Please. 🙏🏻
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
Is it possible to post photos of my screen? First is the Error message 0xc0000034
Then, if I press escape I go to a grey screen : InsydeH2O Stup Utility, with tabs:
Information
Configuration
Security
Boot
Exit
If I press any of the F keys, they do not work
의 공유
you do not show a practically solutions
의 공유
댓글 달기
답변 3개
가장 유용한 답변
Hi @yogaprof
Worst comes to worst and you can't fix it the easiest way to retrieve your files is to remove the HDD from the Lenovo laptop and connect it to the Asus laptop via a sata to USB adapter as an additional drive and copy the files that way.
Depending on what types of USB ports the Vivobook has, you may need either a sata to USB2.0 adapter or a sata to USB3.0 adapter (examples only)
Here's an article that explains what to do.
Here's the maintenance and service guide for the laptop. Go to p.37 (41 of 96 pdf) in the manual, to view the procedure to remove the HDD from the laptop.
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
Hello Jayeff
I truly think that is beyond my capabilities.
Where can I safely download Windows 8 64 bit (not Windows 8.1), as I will try to reboot.
I am following a tutorial in YouTube.
의 공유
@yogaprof
There's a link in @bananakat12345 answer below
의 공유
Information
Configuration
Security
Boot
Exit
의 공유
댓글 달기
Tyr using these commands
Bootrec /fixmbr
Bootrec /fixboot
Bootrec /scanos
Bootrec /rebuildbcd
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Hello Ally
Umm, so when the blue screen appears, I just type all that on the keyboard?
의 공유
댓글 달기
Hi @yogaprof
You can try working your way through these solutions here. You will need a USB with a windows ISO for windows 8 or windows 8.1 (depending on your windows version), put onto your USB with a tool like rufus.
A second USB may be needed to get files off the computer.
Hope this helps.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Hello N Kerr
Umm, I have no idea what all that means. I know what a USB key is though.
I need someone to walk me through, is there anywhere on this site where that can be done?
의 공유
Hi @yogaprof
This guide (https://windowsreport.com/error-code-0xc....) should walk you through the steps clearly.
의 공유
댓글 달기
답변을 추가하세요
YogaProf 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 20
전체 시간: 346
