주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy S21 FE(Fan Edition)는 S21 모델의 파생형으로 2022년 1월 11일에 출시되었습니다. 이 스마트폰은 메인 S21 모델에서 몇 가지가 변경되어 가격이 약간 더 저렴합니다.
Rear Camera (main camera / middle)
Has anyone come across this issue. We have been repairing phones for 8 years and this is a first for us.
Galaxy S21 FE 5G (SM-G990E) We replaced the main camera as exposed when back lens cracked and was damaged.
We have replaced 3 cameras and none work. they are Samsung Service centre parts
  • Camera app, says Camera Failed and closes down
  • *#0*# test menu won't load the camera test
  • Samsung Members app test says send to Samsung service centre.
We have checked the serial number on the original camera is the same number on the replacement. As some charging ports the U / B model is important for function. But Original and New same serial on the part.
the Samsung Self Repair Assistant App, is not available in Australia. We have downloaded the Apk file from US version. and won't run the calibration.
Have I been extremely unlucky and just had 3 faulty cameras or is there some new software issue stopping it from functioning.
  • Safe mode I have tried
  • all software is up to date
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Hi @james17114
Check the status of the LDI (liquid damage indicator) to see if any water/liquid has entered the phone through the cracked camera lens and has caused any damage.
If it is OK or even if not, the service manual will help to find out what's wrong.
I couldn't find a free download online (you may have better luck) but here's a link to a download for a model variant that is not too expensive.
The manual has troubleshooting flowcharts for most of the functions of the phone as well as board layout diagrams. Use the search function of your browser to find the location of the components mentioned in the relevant flowchart. You may have to zoom in a lot to see them ;-)
I don't know about this particular manual, but most also have a comprehensive parts list as well i.e. includes board components e.g. capacitors, resistors, inductors etc as well.
If there is a parts list and if you find the problem and it's a faulty part that needs replacing, search online for Samsung (insert wanted part number) to find suppliers that suit you best.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
James 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 17
지난 30일: 40
전체 시간: 399
