주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Tecno Spark 6 Air 스마트폰은 2020년 7월 30일에 출시되었습니다. 이 휴대폰은 720x1640 픽셀 해상도와 20.5:9 화면 비율을 제공하는 7.00인치 터치스크린 디스플레이를 탑재했습니다. Tecno Spark 6 Air는 쿼드코어 MediaTek Helio A22(MT6761) 프로세서로 구동되며, 2GB RAM을 갖추고 있습니다. Tecno Spark 6 Air는 Android 10으로 실행되며 6000mAh 배터리를 탑재했습니다.
My phone does not charge
why my phone does not charge
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
@samsbits not telling us much. Things like what you have checked and what you have already tried will be important.
This can have many different reasons. First start by making sure that your charger supplies the proper voltage. Next check the charging cable. Make sure that there are no bend. broken. or corroded pins. Now focus on the charging port. A few drops of high-grade isopropyl alcohol and a few puffs of compressed air will clean out the port.
If all of this does not work, then it might be time to disassemble your phone. Think about replacing the battery as well as the USB charging port. Since iFixit does not yet have any guides for that, use something like this video Anything after that, will require some board level repair. For that you need to have the tools, the schematics and the experience to repair that.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Sams Bits 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 12
전체 시간: 149
