주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Bissell SpotClean ProHeat 5207U는 작고 휴대하기 간편한 카펫 청소기로, 좁은 부위의 얼룩이나 엎질러진 오염을 제거하도록 설계되었습니다. 내장된 가열 장치로 잘 지워지지 않는 얼룩을 제거하는 데 도움을 주며, 카펫과 가구 패브릭을 깨끗하게 유지하는 편리한 솔루션입니다.
Leaking from the bottom
Why does it start leaking when I connect the clean water tank? I replaced the tank and it’s still leaking as soon as I connect the tank.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
When you place the tank in the unit, it allows water to pass through a hose to the water pump. It sounds like your hose is leaking or disconnected; first thing I'd do would be to open it up and check the to see if that's where it's leaking from.
Fortunately, someone else has already run into problems with their carpet cleaner and created guides to a few repairs, and luckily one of them shows how to replace that hose.
Bissell SpotClean ProHeat 5207U Hose Replacement - iFixit Repair Guide
Keep in mind you may not have to replace the hose if it's just come loose from one end, but take it out and examine it for any cracks or bulges that might be leaking. Check the connectors on both ends of the hose for any cracked or broken plastic that could be leaking. After you open it up to where you can see the parts, you could put the tank back on and at point the leak may be obvious.
Best of luck; come on back and let us know what you find - your experience may well help the next person who has a leaking carpet cleaner!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Tammy80 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 64
전체 시간: 665
