주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Magnetron always running on microwave
Microwave's magnetron seems always running when start button is pushed.
It doesn't do like the on off cycle
I might think the problem is related to the PCB board
The power relay (the one which supply the transformer) is normally open, when power on it closes but remains closed.
Any suggestion?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @davidetorneri
What is the model number of the microwave oven?
Sounds like the relay contacts are sticking or welded together.
Remove the pcb from the oven and then use an Ohmmeter to check if the relay contacts are short circuit when they're not supposed to be.
If they are, then the relay will need to be replaced.
Usually the relay type/model information is on the relay case. Search online using that information to find a replacement relay that you can solder onto the board in place of the old relay.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Thanks @jayeff
The microwave oven is Samsung MG23F301TCK.
I actually removed the PCB and checked the relay (it has 3 relay in total) checking with a ohm meter without power they are all normally open.
Tested them with a 9V battery they all close.
The PCB model is DE41-00377A
@davidetorneri
Does the timer count down during cooking?
Does the oven "beep" at the end of the cooking time even though it doesn't stop cooking?
If the timer counts down and it beeps at the end, then there's something maintaining the relay operated. Seems like there's a problem in the pcb timer logic
Does it do this on the grill function also i.e stays on after it has finished?
댓글 달기
답변을 추가하세요
davide torneri 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 15
전체 시간: 248
