주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2025년 4월에 출시된 Google Pixel 9a 스마트폰을 위한 수리 안내서, 분해, 문제해결 정보입니다.
Screen glass replacement without pulling screen
I have a crack in the screen protection glass and a replacement for that already on the way.
However, I cannot seem to find a guide for glass replacement only. Is there a chance I can get the original glass off without pulling out the whole screen first?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
선택된 해법
@hannesreisinger nope. You will have to remove the display. After all you will need to heat it up and fit the cutting wire between the display and the glass etc. You also need to re-adhere the glass with some (L)OCA etc. Not something you can do on an installed display assembly.
You do realize that this is not an easy task and will need a lot of practice to be successful. I am not saying you can't do a glass only repair but pointing out that there are many pitfalls.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Oh boy that sounds like something way outside my comfort zone. Cutting wire is the only option to separate the glass?
I guess I should at least have another screen at hand when attempting this... Thanks for the feedback!
의 공유
@hannesreisinger yup. Something like a 0.1mm wire is the common tool for that :-) I agree. Get a new display. I know they are way more costly than the new glass but replacing the complete display is still easier then a Glass-only repair.
의 공유
댓글 달기
Buna am.un pixel 9a display merge dar sticla e crăpată se poate schimba doar sticla și cat costa Mulțumesc
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Hannes Reisinger 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 17
지난 30일: 73
전체 시간: 1,376
