주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
GMC 브랜드로 General Motors에서 판매한 C/K 픽업 트럭(GMC Sierra 포함)에 대한 수리 안내서 및 지원입니다.
How can I fix or replace dash gauges?
Update (09/06/25)
@oldturkey03 Yeah it's a 94 GMC Sierra k1500 .
Seems oil pressure gauge(which I changed few years ago/failing to start) started too be erratic, year later or so the temp gauge goes rt too hot when running a few seconds, (pump replaced years ago, coolant good and no overheat). I changed sensors/wires (two), cleaned MaP sensor, checked grounds, found one broken but had no effect when connected. Didn't replace thermostat yet but have it, my guru says it's likely gauges going, there's motors in them that die off, short of tearing things apart thus breaking clips etc, what else is good or how to take out the cluster and replace it or gauges etc on the very cheap low expense end.
Seems The air/fuel mixture due pcm being told it's running hot (which happened years ago w broker fan belt) causes choking when stopped like it's timing is off-rumbling sensation. Worried about damaging worse then already may have driving
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
@glentrs what exact year and model is your Pickup?
댓글 달기
답변 1개
선택된 해법
@glentrs I'd remove the instrument cluster and take a look at the back of it. See if there are burned/corroded traces etc. To remove the cluster use the service manual page 262. You can now download it from this page 1988-1998 GMC Pickup under the Documents Tab. For a more in-depth information about your cluster, look at the 1994 CK Truck SM that you can get on the same page. Check page 1280 in that manual.
Once you have the cluster out turn it over and take some pictures. Let's see if we can find anything odd looking on it.
기존 질문에 이미지 추가하기
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Ok OT ! I need a few days to get car running good so I won't be without. THANKS for the leads !
댓글 달기
답변을 추가하세요
Glentrs 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 9
지난 30일: 25
전체 시간: 303
