주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Pontiac Grand Am은 Pontiac에서 생산한 중형(이후 소형) 자동차입니다. 1999-2005 세대는 Pontiac Grand Am의 마지막 세대입니다.
Where is the Oxygen Sensor?
Hello, i was trying to fine where to place my oxygen sensory in my 2000 Grand am can you help me thanks.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 1개
How do i know which oxygen sensor is bad and how
댓글 달기
답변 4개
선택된 해법
All 99+ models are equipped with two oxygen sensors. One upstream Oxygen sensor, and one downstream Oxygen sensor. The upstream oxygen sensor is mounted in the exhaust before the catalytic converter, and the downstream one is mounted in the exhaust after the catalytic converter. There is some great info on how to check and replace the Oxygen Sensor right here. Hope this helps, good luck.
이미지
이미지
이 답변이 도움이 되었나요?
점수 14
댓글 달기
It is threaded into the exhaust manifold on the rear side of the engine. You will need a special socket that fits over the sensor and the wire lead.
이 답변이 도움이 되었나요?
점수 4
댓글 1개:
A link to that special socket would really improve this answer.
댓글 달기
The downstream is a ##&&% considering where it is and on my 01 Grand Prix the thing sits about 6 inches from the ground your best bet would be to use a hammer break the bad sensor then socket it off I did it with my upstream last night also unhooking the exhaust helps a bunch with reaching the sensor I'm in the position to where I already wasted money on it but I feel it would be better to put a straight pipe on it and eliminate the sensor completely
이 답변이 도움이 되었나요?
점수 2
댓글 달기
You could get two O2 sensor socket at any automotive parts place
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Dora 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 8
지난 30일: 48
전체 시간: 62,784
