주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
자동 제상 기능이 탑재된 2021년형 독립형 냉장고인 Frigidaire GRFS2853A*의 수리 및 추가 정보입니다. 도어 디스펜서나 제빙기 같은 빌트인 기능은 없습니다. 이 페이지는 GRFS2853A* 패턴과 일치하는 모델 번호에 대한 정보를 다룹니다.
My refrigerator continues beeping
My refrigerator is cooling properly, freezing properly, making ice properly, but the light on the door continuously flashes and it keeps beeping overtime the light comes on. And it is constant. Power cycling it doesn't work. Pulling the power for over an hour doesn't work. Holding the Crush to reset it didn't work. We are about to lose our minds. Any ideas?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 4개
Hi @tonyrogers
What is the full model number of the refrigerator?
What light is flashing?
의
GRFS2853AF0
It is the light in the door water/ice dispenser, under the temperature controls
의
@tonyrogers
Does the water dispenser work OK?
의
Everything works fine. Ice and water. Refrigerator is cooling and freezer is freezing. Just beeps and flashes the light.
의
댓글 달기
답변 1개
가장 유용한 답변
Hi @tonyrogers
I don't know.
The only thing that I can suggest is that you use the service data sheet to run the diagnostic tests and check if any errors are shown.
Maybe perform the tests for the door switches, dispenser paddle and lights first if no errors show when first entering diagnostic mode.
Hopefully it is not a control board issue.
If you find the problem and it's a faulty part that needs replacing, here's the parts list that is useful.
Locate the wanted part in the list and note the part number that is shown for it. Search online for the part number only, to find suppliers that suit you best.
If you search on YouTube for (insert wanted part number) replacement, sometimes if you're lucky you'll find videos that show how to replace the part.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thanks. I will check it out.
의
댓글 달기
답변을 추가하세요
Tony Rogers 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 17
전체 시간: 214
