주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech Lift 인체공학 마우스. 블랙, 화이트, 핑크 색상으로 출시되었습니다.
Left click button does work inappropriately,
Hi
I had used it around 10hrs every weekdays over two years, it is quite a long time use for daily basis because I am full time a drafter and designer. It started not reacting often with the left click button. yeah sometimes work sometimes not.
I've just replaced it with another new lift but if I can fix it, would glad.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 2개
same for me. its a pity, i will reorder new one, but itl sure happen again. i didnt use it that much. but it happened after 2 years too
의 공유
Right button is glitching for me. Purchased Aug 22.
의 공유
댓글 달기
답변 2개
가장 유용한 답변
@hyundongsung check your mouse and see if this is a mechanical or electrical issue. Use something like this teardown Logitech Lift 분해도 to work on it. Check the plastic parts, the ribbon cable as well as the switch board. Let us know if you find anything that looks odd. Sometimes the top of the switches get wore down and the button does not reach deep enough to activate the switch. Adding a small piece of felt to the top of a switch can restore that function. If not, simply check the switches for function with a multimeter and see if they close the circuit when activated.
이 답변이 도움이 되었나요?
점수 4
댓글 달기
Disassemble it and resolder the left mouse micro switch. There's a many different suppliers, but average micro standard is universal. You can replace this with soldering iron or station.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Hyundong Sung 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 13
지난 7일: 64
지난 30일: 330
전체 시간: 3,329
