주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Latitude 3510은 2021년에 출시된 비즈니스용 노트북입니다. 이 안내서는 노트북 수리를 지원합니다.
keybord backlit is not working
my laptop has backlit keybord but suddnly it stops working where i have tried to updare all the drivers and BIOS related to keybord but still there is no progress i think its a hardware problem if anyone can help me with this problem
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
@vanimation69899 here is the Dell Latitude 3510 Sm. It will help you to work on your computer. The motherboard for your laptop should be a UMA 6L 19746. There is a resettable fuse for your keyboard backlight.
이미지
You may just need to check that ;-) as well as power to the back light (+5V_KB_BL) You can do that on the capacitor C6501on your motherboard.
이미지
Not the greatest image but it should help to identify the components listed. Of course, also check your ribbon cable to make sure it is properly seated and has no rips or tears.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
From what you provided, it seems you are right. I am not familiar with any Dell Latitude 3510s, but I believe that the power cable for the backlight is loose. Try opening it and unplugging and plugging the power cable back in.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
V Animations 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 25
전체 시간: 267
