주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kenmore는 Sears에서 흔히 판매하는 유명 가전 브랜드이지만, Sears가 직접 가전을 제조하지는 않습니다. 대신 위탁 생산을 통해 다른 제조사에서 제품을 만듭니다. Kenmore 냉장고는 LG, Electrolux, GE, Whirlpool을 포함한 다양한 제조사에서 만듭니다.
Door bottom support broken
Refrigerator door is misaligned. Too low, scrapes the bottom of inside of frig as you try to close. Tried a taller leveling screw but bottom of frig door just collapses and door will not get back to original location. Is the bottom of the door that supports the leveling screw replaceable or fixable. Thx
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개:
Hi @bdwest23242
What is the model number of the refrigerator?
의
253.67879509
의
댓글 달기
답변 1개
Hi @bdwest23242
If the lower door scrapes the inside of the compartment, it may be a loose lower hinge bracket, worn hinge pin or spacer.
Here's a video that shows how to replace the hinge pin that may help.
It shows how to gain access so that you can check if the bracket (bent/loose?), the hinge pin (worn?) and spacer are all OK or not.
If replacements are required, the part numbers are as follows. Search online for the part number only to find suppliers that suit you best.
lower hinge pin = 240516502
spacer = 240311303
lower hinge bracket = 240314011
Note: The refrigerator is a Frigidaire model, made for Kenmore as it is made entirely from Frigidaire parts. That's why parts results show Frigidaire name. Kenmore doesn't make appliances, they rebadge/made to order other makes of appliances e.g. LG, Frigidaire, Whirlpool etc
Connects the refrigerator door to the lower hinge, allowing it to pivot. 이미지
제품
Electrolux Refrigerator Lower Hinge Pin - 240516502
$53.99
Supports the refrigerator door at the lower hinge point. 이미지
제품
Electrolux Bracket-Lower Hinge - 240314011
$65.99
Nylon washer for refrigerator hinge, sold individually. 이미지
제품
240311303 - Frigidaire Refrigerator Hinge Nylon Washer
$18.99
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Unfortunately lower bracket all good. So is pin and spacer. It’s the door itself that has an issue. Caved in and can no longer support the pin. Thx for the reply. I’m assuming I would have to change door. Correct ?
의
@bdwest23242
Looks like it will have to be as they're a sealed unit i.e. filled with foam insulation
According to this parts supplier there are 3 doors compatible with the model
Part # 241623407, 240438617 & 240438619 click on Door parts diagram, expand the diagram to see part #15 in the diagram.
의
댓글 달기
답변을 추가하세요
Bdwest 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 15
지난 30일: 19
전체 시간: 208
