주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony SRS-XG300 무선 스피커는 Sony에서 제작한 블루투스 스피커입니다. 이 인기 있는 스피커는 연결된 소스 기기에서 음악과 오디오를 스트리밍하는 데 사용됩니다. 이 스피커는 강력한 저음과 선명한 보컬 재생 능력으로 잘 알려져 있습니다.
AUDIO IN Jack does not recognize connection
Audio device output does not play on speaker. Bluetooth audio still works. Previously, inserting mini-stereo cable into AUDIO IN jack would prevent Bluetooth audio--this is not the case now. I have tried 3 different mini-stereo cables, audio device does output sound to earbuds through its mini stereo connection.
The Sony speaker did work two weeks ago. I went on trip and removed connections and placed speaker in its carrying case. I did not use the speaker during the trip. But it does not operate correctly upon my return home in its normal configuration.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Hi @davejones7666
Sounds like it may be a faulty audio jack.
Some audio jacks have internal changeover contacts that when operated by the insertion of the audio cable plug, operate to disconnect the BT audio input from the speaker and connect the audio cable input to the speaker instead.
Other types of audio jacks have a single internal make contact which operates to signal the audio controller on the board to switch the audio from the BT source to the audio input source.
I don't know which type is used in the speaker but here's the ifixit Sony SRS-XG300 repair guide that will help to gain access to the inside of the speaker so that you can check if the audio jack is working OK electrically when the cable is inserted.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Dave Jones 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 11
전체 시간: 202
