주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple의 M2 SoC가 탑재된 2022년형 13인치 MacBook Air에 대한 수리 안내서, 지원 및 문제 해결 정보입니다. 2022년 7월 15일에 출시되었으며 모델 번호 A2681로 식별됩니다.
This makes no sense!
Hi all, really hoping I can get some help here!
So, in a nutshell, My MacBook won't turn on without being connected to power, and it only connects to power if you unplug the charger from the wall, disconnect the MagSafe charger, then plug both in. Once it boots up it's always showing the date as Thursday 1st April at 8pm, and it says the battery is always at 85% charged. But when I disconnect the charger, the laptop dies, and I have to go through the process again. System info says my battery condition is normal and it's only done 71 cycles so I have no idea. any help would be great!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 3개:
Let's get a bit of deeper info. Install this gem of an App CoconutBattery take a snapshot of the Apps main window and past it here so we can see it. If you can click on the battery info button as well. With that we should be able to figure what's happening.
Hey Dan, everything looks to be fine, shows battery charge at 84.1% and battery health at 95%. Full charge capacity 4,336 mAh, Design capacity 4,563mAh, 71 charge cycles. does say charging with is 0mW if that stands out?
@c53dgx8yju3rgxe - Yes! The zero charge is one element. But it would be easier just seeing the full image with all of the data.
댓글 달기
답변 1개
It sounds like your MacBook isn’t getting proper power from the battery despite it showing as “normal.” The issue likely stems from a faulty battery connection, a defective charging circuit, or a failed SMC (System Management Controller). Try resetting the SMC and NVRAM, then test again. If that doesn’t help, open the MacBook and check the battery connector for loose contacts or corrosion. The constant April 1st date indicates loss of real-time clock power—another sign the battery isn’t providing voltage to key circuits. Replacing the battery or checking the logic board’s power IC may be necessary to fix the problem.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
It's best to try to isolate down the fault than throwing so much at the wall to see what sticks. Clearly it's a power issue but where? Which of the many areas would you focus in on?
Rashmi on an MacBook Air m2 2022 you cannot reset the SMC, I have tried rebuilding and everything and I still have the same issues
댓글 달기
답변을 추가하세요
janesboy 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 44
전체 시간: 306
