주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2021년 6월에 출시된 MSI GS66 Stealth는 NVIDIA의 노트북입니다.
No Power to computer when plugged in
I just plugged in my MSI GS66 after not being used for over a year. I get no power. I cleaned the power port and it is not clogged. If my battery is completely dead will I get power to the laptop? If not, do I need to replace the battery?
Thanks
Russ
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
If a laptop battery sits completely discharged for over a year, it may have entered deep discharge or “sleep” mode. Most modern laptops, including MSI, will still power on from AC even if the battery is dead — but there are exceptions:
Some MSI models require the battery to be recognized for the power system to initialize.
If the battery has chemically failed, the laptop may refuse to charge or even turn on.
A deeply discharged or “frozen” battery may short the power circuit, preventing AC-only startup.
So yes — a completely dead battery can prevent the laptop from powering on, depending on the model and condition.
Terrific help Aashok, thank you!
댓글 달기
답변 1개
가장 유용한 답변
Try an EC reset: unplug the charger, hold the power button for 60 seconds, then plug it in again. If still dead, test or replace the charger, then reconnect or replace the internal battery. If no lights appear, the motherboard power circuit may need service.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thanks for the excellent help Rashmi! I tried he EC reset and it didn't work. My additional question is wouldn't it be more logical to assume the battery is deficient vs buying the power supply which doesn't have a shelf life? Battery is probably more expensive but probably more chance that it is the culprit. What are your thoughts?
댓글 달기
답변을 추가하세요
Russ 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 24
전체 시간: 342
