주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple이 설계한 M1 Pro 및 M1 Max SoC를 탑재하고 2021년 10월에 출시된 16-인치 MacBook Pro에 대한 수리 안내서 및 분해 정보입니다. 모델 A2485.
I need this cable
Broke this cable replacing the screen and now the keyboard does not work
이미지
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
That is the lid angle sensor cable. What is your exact model (year) as there are a few different versions.
의 공유
Hi and thanks for responding, it is a 2021/2022
Model: A2485 EMC: 3651
Would this cause the keyboard to not work?
의 공유
댓글 달기
답변 1개
선택된 해법
Yes the sensor cable needs to be connected and working. Apple in this series requires the sensor to be calibrated if you change it. Also note a new part will not have the sensors firmware downloaded to it yet so that will require access to Apple's paywall tool by buying the part directly from them (see the lower answer segment)
Getting a used part is the cheaper way and the magnets frame on the lids side can be rotated you should be able to dial in the adjustment by carefully rotating the magnet so the sensor already programmed setting is reused. With the newest macOS you can also review your parts and by pass Apples serialization as they caved on it. Sadly many used parts houses only have the new part presently which depending on your OS level maybe an issue. I haven't tried the onboard recalibration process yet on this series so I can't tell you if it works or not.
Here's the details on the needed part: Lid Angle Sensor 661-23648
To get the part directly from Apple from their Self Service site Apple self-service Repair just go to the #2 option to order it and the Apple official repair manual is here 16" MacBook Pro (2021) repair manual
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Thank you for the info! I am going to try the used method. F Apple!
의 공유
댓글 달기
답변을 추가하세요
Corey Hardenburg 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 14
지난 30일: 53
전체 시간: 282
