주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 또는 3.8 GHz Core i5 또는 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K Display. 시스템이 매우 유사하므로 이전 iMac Intel 27" Retina 5K Display (Late 2014 & 2015) 안내서를 참고하십시오.
OEM hard drive replacement
What is the Kit for an OEM hard drive replacement
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Is this what you are looking for? SATA HDD to SSD upgrade or PCIe/NVMe Blade SSD upgrade
And here's the two guides:
The HDD drive swap-out is the easiest to do, but the Blade SSD offers better performance.
Do keep in mind if you have a Fusion Drive you have both drives present! And you will need to disable the Fusion Caching SSD (Blade Drive) otherwise you'll encounter issues as it wants to join the fun which you don't want!
The easiest way to disable it is once you have the system running open Disk Utility and make sure you select show all volumes so the hidden Cache drive can be selected and reformat it deleting it fully. Is mostly a useless drive as it's too small to effectively hold the OS.
Upgrade the storage and improve boot time and read/write speed in your iMac Intel 27" Late 2012-2019 with this SSD upgrade kit. 이미지
제품
iMac Intel 27" (Late 2012-2019) SSD Upgrade Kit
$115.99
Upgrade your iMac with a new SSD to dramatically speed up your machine. 이미지
제품
iMac Intel 27" (Mid 2017-2019) SSD Blade Upgrade Bundle
$249.99
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Core Solutions 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 5
지난 7일: 10
지난 30일: 18
전체 시간: 153
