주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung RS25J500D** 냉장고 수리 및 정보 안내서입니다. 이 냉장고는 빌트인 디자인, 자동 제빙기, 도어 정수/제빙 서비스를 갖춘 양문형 모델입니다. 이 페이지는 RS25J500D** 모델 번호 패턴과 일치하는 기기에 대한 정보를 다룹니다.
Ice maker water leak?
I just purchased a used side by side that cools fine, but I am having problems with the water/ice maker. When I turn on the water, I get an immediate leak. It is as if a broken line, valve or what ever. It is coming from the top of the ice making tray. Any suggestions as to what it might be or how to troubleshoot?
이미지
Update (11/21/25)
Further inspection finds that the water is coming from here; from a silicon tube extending from the ceiling of the freezer. I am guessing that there is a float or weight valve somewhere that is not working. The icemaker does produce and deposit ice, but the water will not shut off on its own.
Yes, I did take the door off to instaul the fridge. Is it possible to have plugged the wrong wires together? The connections did look similar
이미지
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi @randyjaco
Reassemble the ice maker back into position and then run the Self-Diagnostics function - either during Initial Power On (assuming you had the power disconnected when working on the ice maker) or during normal operation as shown on p.40 of the service manual and check if any error codes are displayed.
If error code 6 is shown go to p.41 to find out what to try.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Thanks for the response and especially for the Service Guide. I was just about to buy one. It appears that the water valve is bad, so I will be ordering one. Hopefully that will solve the problem.
댓글 달기
답변을 추가하세요
Randyj 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 15
전체 시간: 154
