주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
충전기와 배터리를 포함한 전동 공구 액세서리 및 부품에 대한 수리 안내서와 분해 가이드입니다.
help identifying a resistor value
Can someone help me identify a busted resistor in first picture, it's shorted so I cannot read it with multimeter. It's to a Milwaukee 12v battery charger.
I cannot tell which end to start reading from, I know the ones closer together are read first but these look equidistant to me. It's either 1M ohms or 140 ohms. guessing 1M, but want input b4 soldering in
Second picture is a resistor 2 spots over that is 1.5m ohms as the brown green and black are closer to each other than the yellow. But on the first one, all look same distance to me.
이미지
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @chrisguzek
What is the model number of the charger?
Looking at a zoomed in view of the 1st image it appears that the brown band is marginally closer to the black band than the brown band at the other end is to the yellow band so that would make it a 1M Ohm 1% tolerance resistor.
Maybe the best option is to get both i.e. the 1M Ohm and the 140 Ohm and install the 1M first and check if the charger works OK.
Thinking it would either not work or would cause less damage if it is the wrong one than vise versa.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Chris Guzek 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 39
전체 시간: 239
