주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Surface Pro 태블릿의 4세대 버전입니다. 2015년 10월 26일에 출시되었습니다.
surface pro 4 battery replacement
Do all model of Surface pro4 use the same battery because I am not sure if would order a correct one?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Yes, all models of the Microsoft Surface Pro 4 use the same battery.
The Surface Pro 4 (model 1724) has a single battery design across all configurations (Core m3, i5, i7; different RAM/storage options).
The battery specs are consistently:
  • 38.2 Wh
  • 5087 mAh
  • 7.5 V
Common part numbers include:
  • G3HTA027H
  • DYNR01
This is confirmed by repair services, iFixit replacement parts, and listings on sites like Amazon and eBay, which all reference the same compatible battery for the entire Surface Pro 4 lineup. You can safely order a replacement battery labeled for "Surface Pro 4" or "model 1724" without worrying about variations between sub-models.
Tips for Replacement
Battery replacement is possible but challenging. It involves heating and removing the glued screen (high risk of breakage), disconnecting components, and carefully handling the strongly adhered battery.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Kenny L 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 31
전체 시간: 338
