주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2020년형 ASUS G15 G512LI의 수리 및 분해 안내서입니다. 이 노트북은 ASUS에서 가성비 및 보급형 게이밍 용도로 출시했습니다.
Screen went totally black
I got flickering in my screen and I powered off normally. When I opened back the screen was full of stripes. Rebooting once the screen went full black. I thought the display was the issue and tried changing it but no good even the ASUS authorised service centre said no issues in display screen.
By digging deep they said something went wrong and I need to replace the mother board. Is there any way to fix this
On the good part I can connect to external monitor by this way I can use my laptop
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
@kavin41097 this "On the good part I can connect to external monitor" makes me wonder why you would need to change the motherboard. This sounds like an issue that is related to your LCD and not the processor. Looks like your laptop has 2 GPUs. One is the integrated Intel, which is combined with the CPU, and a discrete Nvidia which is separate. The Intel will work until your computer loads the OS (Windows I assume) which will then direct the video to the Nvidia processor. That means you should see a picture right up to the point where Windows is loading.
Check you LCD screen and the display cable. Also, check the display connector on your motherboard. Post some well focused pictures of that with your question. It will help if you can tell us what exact motherboard your computer uses. It is printed on the board itself, but maybe on the underside.
Looks like the display cable is part number LVDS Flex Video Cable 14005-03070000
기존 질문에 이미지 추가하기
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Kavin 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 28
전체 시간: 215
