주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
이 휴대폰은 6.50인치 터치스크린 디스플레이를 탑재하고 있으며, 해상도는 720x1600 픽셀, 픽셀 밀도는 269ppi(인치당 픽셀 수), 화면 비율은 20:9입니다. Oppo A53 2020은 1.8GHz 옥타코어 Qualcomm Snapdragon 460 프로세서로 구동됩니다. 4GB RAM이 장착되어 있습니다.
Camera front not working
Camera not working
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 4개
We need some more info: does the camera app open normally? are you getting an error code? when did the problem start? does the rear camera work? does the phone have any other issues?
의 공유
@teardowns101 been there, done that (for years). Feedback and clarifications very seldom happen with this type of questions. You will find that most of these actually get totally abandoned. Go ahead and answer those with the best possible solution that you can think off when you read those question. Somebody else may actually benefit from your answer. You can always amend or edit your answer if additional information from the OP becomes available.
의 공유
@oldturkey3 haha, you're right, I guess I'm just an optimist at heart! Good point about providing a solution for others---I've gotten help on the forums before from reading answers to other people's questions, even if the solution didn't work for them!!
의 공유
@teardowns101 same here. That is why I think we do need to cherish and reward those OP's that are coming back and interact etc. It makes up for the many that don't. It can get pretty frustrating when you want to help someone and then there is no feedback. Don't let it discourage you and keep on trucking along ;)
의 공유
댓글 달기
답변 4개
가장 유용한 답변
@samsunga2117500 start your phone in safe mode. You do that by pressing and holding the power button, then tap and hold "Power off" on the screen until a "Reboot to safe mode" prompt appears. Tap "OK" to restart. You can also turn off the phone, turn it on, and hold the volume down button when the logo appears.
Once in safe mode see if your front camera works. If so then you have a 3td p[arty App that is blocking regular access to it. You would need to uninstall those 3rd party Apps. There is no certain way to determine which App so you would start be deleting one after the next 3rd party App.
If your camera even in safe mode does not work, then the issue is most likely with the camera itself. You may need to consider replacing the camera model. Since iFixit does not yet have a specific guide for that, use the teardown from here to work on it. Of course, you do not need to remove the charging board etc. The camera modules are readily available.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same issues with their device. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
الكاميرا الامامية عندي معطلة
이 답변이 도움이 되었나요?
점수 0
댓글 달기
https://youtu.be/s-ebktoSLgo?si=LBiqaR8d...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Front camera white screen
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Samsung a21s 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 41
전체 시간: 398
