주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Repair and disassembly guides for Brother printers.
wifi Direct button disabled on MFC5750
So the WI-FI Direct button seems to be disabled. Whw i push it nothing's happening, just i hear a bip sound.
Wherever I found something about this, the instructions start with "Press the wifi Direct button" but for me I press it in vain because it is inactive.
Do you know how to activate this button?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @marcel7577
Check if the WiFi Direct option has been turned off.
On the printer go to Settings → Network → WiFi Direct → I / F Enable to either turn it on or off
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
I can't enter the WIFi Direct menu because it's disabled. That's exactly the problem
@marcel7577
Try resetting the network and check if it works after that.
Go to Settings → Network → Network reset.
@jayeff
I solved it. I disabled wlan and activated wifi Direct.
It took me a while to realize that on the same wifi device, wlan and wifi direct don't work at the same time...
It would have been nice if brother said that wifi direct doesn't work at the same time with wlan.
thanks
댓글 달기
답변을 추가하세요
Marcel 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 31
전체 시간: 123
