주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to replace keyboard
Keyboard backlight is not working so I wan to fixit by replacing it fixing the old one
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
@swiftbrown get the hardware maintenance manual for your computer from the Documents tab on this page Lenovo Yoga C630-13Q50 It will help you with working on your computer. Once you have it open, check the backlight cable. Make sure it is properly seated and does not have any tears, corrosion etc. If it is okay, then the issue will most likely be on your motherboard (should be a LA-G611P). Pin 1 and 2 are ground and pin 3 and 4 are +5V you can measure that with a normal multimeter. If your motherboard does not have the voltage, you will need to check the circuitry.
이미지
For anything more complex, we will need to see your motherboard and need you to verify the model for your motherboard.
기존 질문에 이미지 추가하기
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Had this happen to me too, I just cleaned the contacts and reconnected the ribbon cable, then it worked. If not, you can replace the backlight but check your model guide first. Most times its just a loose connection, not broken light.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Swift Brown 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 27
전체 시간: 91
