Remove alternator from engine
I have alternator broke but can't find space to pull the alternator out
좋은 질문입니까?
좋은 질문입니까?
@donaldmart53225 here are the instructions for the Generator Removal from the workshop manual. If there is anything in the way etc. you want to go ahead and post some good pictures of your situation. That way we can see what you see and hopefully find a solution. 기존 질문에 이미지 추가하기
@donaldmart53225 all the wires are loose and your removed all the bolts etc.? Where are you stuck? You normally are supposed to drop the engine. Take a look on here to see how to try and do it without dropping the engine, or on here where you drop the engine.What a PITA
이 답변이 도움이 되었나요?
지난 24시간: 3
지난 7일: 8
지난 30일: 29
전체 시간: 200
댓글 1개
Alternator is loose but I can't get out frustrating
Donald Martin 의 공유
