주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Cyber-shot DSC-W55는 2007년 초에 출시되었습니다. 이전 모델의 5.1메가픽셀 카메라에서 7.2메가픽셀 카메라로 업그레이드되었으며 56MB의 내장 메모리를 갖추고 있습니다.
My Lens does not focus.
My son dropped my DSC-W55 and now while focussing, I can see blurred images. But if I gently push the lens from outside, I can focus clearly. But if I try autofocus, then due to the lens movement, the lens defocuses again. I need to repeat the 'Push' action every time I need to click a picture. Can someone Help me get it resolved? I took it to the Repair centre, they wanted me to change the entire Lens unit, but I believe there should be some fix, other than replacing the unit. THANKS !!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
Would you be comfortable to disassemble your camera right down to the lens block itself?
의 공유
Yep. I would be happy to disassemble if I could get it fixed. I wanted to check if there was any minor problem.
의 공유
댓글 달기
답변 2개
선택된 해법
TKS, download the service manual from here. Scroll down to Service Documents and click on the links. It will show you all the details and should help to trouble shoot. Hope this helps,good luck.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Minha máquina não liga mais e parou do nada. O que pode ser?
의 공유
댓글 달기
가장 유용한 답변
Hello,
Your camera uses several other factors when auto focusing including infrared or sonar. It sounds like when your son dropped it, You may have jarred one of these sensors. Replacing the lens is an option that i would use last.
My suggestion to you. Manually focus the lens to extend then gently wiggle it back and forth to allow it to recenter in the tube. It retracts and may have been shaken off track.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
@Gametech. Thanks .. I will try the suggested fix. But do you want me to open the Camera and do this?
의 공유
댓글 달기
답변을 추가하세요
TKS 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 15
지난 30일: 69
전체 시간: 9,919
