주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2021년에 출시된 HP ZBook Firefly 15 G8은 신뢰할 수 있는 성능과 휴대성을 필요로 하는 학생 및 전문가를 위해 설계된 15.6인치 경량 모바일 워크스테이션입니다. 다재다능한 하드웨어는 일상적인 업무 생산성, 창의적인 애플리케이션 사용, 그리고 다양한 수리 및 업그레이드 옵션을 지원합니다.
display or lcd problem .
I am facing some problems with my laptop display, like if I play YouTube for 1-2 hours on Google Chrome, when I go from YouTube to another app or site, I still see that part of the display that shows the YouTube logo and the area where the video was playing shadowed out. Not Only Youtube, after running Facebook or any other application and exiting it, I also see light traces of that application on my screen. However, the LCD test performed on the laptop does not indicate any such problem. However, I encounter that problem when running any other program. These marks disappear on their own when I keep the laptop closed or shut down for 2 to 3 hours. As you can see in the image, I was working on Google Sheet for some time, but when I leave the site, I still see the Google Sheet work in the display. is that a display problem?#help
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 5개:
Hi @saifaliaman
Does the problem occur when using either the Nvidia GPU or the integrated Intel CPU Graphics for the video or does it only happen when using one of them?
의 공유
@jayeff YES its NVIDIA T500 {GPU} AND Intel(R)Iris(R)Xe Graphics {GPU}
의 공유
@saifaliaman
So the problem occurs when using either GPU, is this correct?
Have you checked in Device manager to see if the latest graphics drivers are installed?
의 공유
it says the best drivers for my windows are already installed
의 공유
@saifaliaman
Have you tried changing the screen resolution or refresh rate to see if doing this altered anything?
의 공유
댓글 달기
답변 1개
Hi, @saifaliaman I gotchu.
This calls for a screen or logic board replacement.
This looks like a major issue, probably a faulty Nvidia GPU. If your Nvidia looks fine, this might be a logic board issue. Send me a screenshot of the diagnostic test, so I can see what's going on here. There is a higher chance this is a faulty logic board/CPU issue.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
{CPU}-11th Gen Intel(R)Core(TM) i7-1165G7 @ 2.80Ghz.
Memory 16.0 GB.
Disk 0 (C: D:) (SSD)
MTFDKBA512TFH-1BC1AABHA
Capacity: 477 GB
의 공유
This is a logic board issue, I suppose, as the NVIDIA is working fine. Ask the new FixBot.
의 공유
댓글 달기
답변을 추가하세요
Saif Ali Aman 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 43
전체 시간: 224
