주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PlayStation 3(줄여서 PS3)는 소니 컴퓨터 엔터테인먼트(Sony Computer Entertainment)에서 제작한 세 번째 가정용 게임기이며, PlayStation 2의 후속 기기입니다. 2006년 11월 11일에 출시되었습니다.
Help fixing black screen of death?
About a year ago, I had interest in jumping back in a game on my 1st gen fat ps3. The system booted up fine and had an update. Mid update, the screen went black and never came back to show anything, so I shut off the ps3. Now, when I turn it back on, it only goes to a black screen.
Things I have tried:
-Holding the power button to reset the video settings - no change
-Switching HDMI cables and also trying AV cable - no change
-Switching TVs - no change
-Holding the power to put the ps3 into safe mode - did not work. Safe mode does not seem to load up, and still only a black screen
-I bought a new HDD - This was the most encouraging attempt. The ps3 turned on properly and went through the OS installation process, but then immediately went back to a black screen.
-I've tried loading the latest ps3 firmware update onto a USB flash drive (formatted to FAT32) - no change
-When I turn on the ps3 with no HDD in the system - I do get a video signal and an error message that says "The appropriate system storage was not found"
The best attempts I have are related to the HDD. Though, I'm confused that I wasn't able to install the OS and fix the system using the new HDD...so I'm out of ideas at the moment.
Any help on this would be absolutely amazing!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Hi!
That would be my first attemp to fix it as well. With a brand new HDD and installing the software from scratch. Unfortunately,, this didn’t fixed it :(…
Did you also tried the AV cables after replacing the HDD? Also, what happens if you try to enter the safe mode?
So far it sound like the firmware is corrupted. Which is pointing toward the motherboard…. Replacing that will most likely work, but is very expensive…
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Try downloading the latest ps3 firmware onto a usb stick. Then with the ps3 off press and hold the power button for about 5 seconds AFTER the beep then let go. Hopefully an option screen will pop up.
It’s a bit of a process so google ps3 manual update. Follow the process for file format, location etc as set out on screen. My ps3 sat for 3 years and had the same problem.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Alex V 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 22
지난 30일: 79
전체 시간: 611
