Why the air compressor not starting?
Why air compressor not starting
좋은 질문입니까?
@innocentmutepfa start by checking fuse #28E which controls the compressor clutch relay. If your fuse is good, you will need to check the relay. Here is the Land Rover Discovery 4 HVAC Wiring diagram. Use that to check your compressors power lines.
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 12
지난 30일: 29
전체 시간: 127
댓글 1개
@innocentmutepfa have you checked your fuses? What have you checked and tried already?
oldturkey03 의
