주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
My phone is ghost touching
After changing the screen the phone just operated normally or properly for a day and suddenly started to press keys itself.I tried to press the volume keys and power at once but couldn't work out.what could have caused this problem?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
@willykaputa could be a bad replacement. I would ask the seller to refund you or, if you used a repairer to replace the screen, to do it once more. Anything else will be on the main circuit board. Could be the connector or could even be an issues with the circuitry. First step should be to replace the screen once more. If it happens again, you know that you will need to have somebody check your circuit board.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Willy Kaputa 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 7
전체 시간: 71
