주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
GE 스토브, 오븐, 레인지 및 쿡탑에 대한 수리 안내서와 팁을 포함한 정보를 확인해 보세요. 다양한 GE 스토브 및 오븐 모델의 일반적인 문제를 해결하고 고치기 위한 상세한 지침을 제공합니다.
GE CAFE Range Replacement of Touch Screen/Controller
This question is for GE Cafe dual oven model CC2S950P2M1S1 or any similar model. The extra C in front indicates a Canadian model.
Just thinking ahead, I noticed that there is an info option on the touch screen menu of the display panel that provides the model # and software version.
If this controller ever needs to be replaced, does a GE technician or a person with the right tools have to program this controller to match the particular model. If not, how does the controller board identify the range model?
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @gusg51821
I couldn't find the mini manual for the oven online (GE p/n 31-17271) but here's a link that shows where it may be located in the oven or if it's not there how you can get it.
Normally, mini manuals have the diagnostic test procedures and the wiring diagram and sometimes they may also contain other information like what you're after but not always
I'm not sure if this information also applies to Canadian GE appliances or not. If the manual is not found anywhere in the oven, it never hurts to ask
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
It is a double oven model, so in all likelihood it will be located behind the control panel. I will keep this in mind for the future.
Thanks Jayeff for taking the time to respond.
댓글 달기
답변을 추가하세요
Gus G 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 21
전체 시간: 189
