주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
3세대 픽셀 휴대전화의 일부인 3a는 구글의 플래그십과 동일한 카메라를 탑재한 실속형 옵션입니다. 클리어 화이트, 저스트 블랙 또는 퍼플 색상으로 제공됩니다. 2019년 5월에 출시되었습니다.
USB File Transfer and Debugging not working
Hey Everyone,
I thought my Pixel 3A had faulty USB-C port as except charging it does nothing else i.e File Transfer and USB Debugging.
I ordered and replaced the USB-C port last week successfully but the result is the same.
Anyone else faced the same issue ?
Thank you
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개:
Hi @pbiswal
When you plug in a USB-C cable is there a notification on the phone stating "Charging this device via USB"?
If there is when you tap on the notification are there other options to select e.g. "Use USB for File Transfer"?
If there is and you tap on it and it still doesn't work, have you tried using a different known working USB-C cable?
의
I am having the same issue
의
댓글 달기
답변 2개
On the Google Pixel 3a, if charging works but data doesn’t—even after replacing the USB-C port—it’s usually not the port itself. Check the USB mode in settings (set to File Transfer), try a different data-capable cable (many are charge-only), and test on another PC. Also clean the port gently for lint.
If still no detection, it could be a damaged USB controller IC or motherboard issue. Enable Developer Options → USB Debugging and see if it’s recognized. If nothing works, it likely needs board-level repair or professional service.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
This didn’t work for me, all usb options are grayed out on my pixel 3a, as well as usb debugging not showing up. It can only charge
의
댓글 달기
Usb debugging isn't usually turned on as standard.
To turn it on,
Go into settings and about phone.
Look for 'Build number'. If not there look under 'software'.
Tap and keep tapping on the words 'build number' until it says developer options enabled or similar.
Click back into the main settings menu and a new developer options folder should be there.
Click the new folder, scroll down to usb debugging and turn it on.
Then try it.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Priyabrata Biswal 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 28
전체 시간: 201
