주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Toyota Vitz는 1999년 Toyota Starlet의 후속 모델로 처음 출시된 소형 해치백입니다. 현재 Toyota Yaris 또는 Echo라는 이름으로 전 세계에서 판매되고 있습니다. Toyota Vitz는 현재 4세대까지 출시되었습니다.
Sparkplug engine car shaking
Only my right sparkplug turns black every week and then my car starts shaking when I drive?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
@yahvehhuisraad this will depend what the spark plug face actually looks like.
이미지
If it is black with soot, it is most likely because of a bad air/fuel mixture. To address this, we will need to know the exact year and model for your Vitz. Make sure you have the right spark plugs installed.
If it is black and full of oil, you are burning to much oil which can be caused by bad valves or bad piston rings etc. For that you would need to start with a compression test or better, a leak down test.
This "then my car starts shaking" is because your spark plug does no longer fire properly (if at all ) and thus your engine performance goes down, your car will have poor fuel mileage and poor idle etc.
Let us know what you find out.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
When compression is low, the spark plug will usually become coated with a black, oily deposit.
But it could be something else. I'd swap the sparkplug and wire and see. If the problem now resides in a different cylinder, then I'll need to replace the wire and sparkplug. The ignition coil could also be the issue.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Yahveh Huisraad 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 32
전체 시간: 186
