주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2002년 Electrolux Home Products - Minnesota에서 출시한, 제빙기가 없는 상냉동 하냉장 방식의 Amana DRT1802B* 냉장고에 대한 수리 및 추가 세부 정보입니다. 이 페이지는 DRT1802B* 모델 번호 패턴과 일치하는 제품에 대한 정보를 다룹니다. 자동 성에 제거 시스템과 냉장실 문을 갖추고 있습니다.
Water leaking into bottom
Why does water accumulate in bottom
Update (03/28/26)
It’s pooling in bottom of refrigerator!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Hi @haroldmcnelly
The water could be coming from the freezer compartment when the refrigerator is in the defrost cycle.
During the auto defrost cycle the compressor and the evaporator fan are both turned off and a defrost heater under the evaporator unit is turned on to melt the accumulated ice that is covering the evaporator unit.
The melt water then drains down a tube which comes out above the drain pan which is located under the compartments near the compressor motor where it then evaporates naturally.
Disconnect the power to the refrigerator and check that the drain tube is not blocked with dust (or insects etc) where it comes out above the pan, as this could cause the meltwater to backup and overflow from the freezer compartment and into the refrigerator compartment.
If the drain hose is clear etc disconnect the power to the refrigerator and then remove the panel, inside at the back of the freezer compartment to gain access to the evaporator unit which is behind the panel. (Access to the panel is through the freezer door at the front)
Under the evap unit is a trough where the ice meltwater collects and then flows down through a hole (which the hose is connected to) and drains down to the pan underneath. Pour a measured amount of water into the trough (1 cup) and check that all of it reaches the pan underneath.
If hardly any water gets to the pan and ends up in the refrigerator compartment, then the hose may have come adrift from the fitting under the trough. Unfortunately I cannot find any information re your model how that would be accessed.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Harold McNelly 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 23
지난 30일: 51
전체 시간: 202
