주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Itel L6502는 Itel Vision 1 Pro로도 알려진 보급형 스마트폰으로 2021년 1월에 출시되었습니다. 6.52인치 HD+ 디스플레이를 탑재하였으며, 기본 쿼드 코어 프로세서와 2GB RAM으로 구동됩니다. 일반적으로 최적화된 Android 10 (Go Edition) 운영 체제를 사용합니다.
How to fix the charging system
How to fix a charging system port
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 10
댓글 5개
how to fix charging port
의 공유
@zai6292 See the charging port replacement video posted in @oldturkey03's answer.
의 공유
Charging system is disturbing me I would like to repair
의 공유
How to repair the charging point
의 공유
Show me Counties the screen
의 공유
댓글 달기
답변 2개
가장 유용한 답변
@mainalyton you are not telling us what the issues are (I assume it is not charging) nor are you telling us what you have already checked and tried. Of course, you always check your charger and your charging cord. Make sure you have the proper voltage and that your cable is in good working order.
Next, you want to check your charging port. Make sure that it is clean and does not have bent pins. Use a few puffs of canned air to clean out any pocket lint etc. If all of that is okay, then a charging issue can be caused by a bad charging board, a bad battery or a bad cable from the charging board to the mainboard. I would start by replacing the battery and the charging board at the same time. That way you only have to open your phone one time.
Since iFixit does not yet have a guide for that use a combination of this video for the charging board, as well as this video for the battery.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same issues with their device. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Open the phone and remove a panel and use a hot air station to replace a pot
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Maina Lyton 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 5
지난 7일: 26
지난 30일: 70
전체 시간: 682
