It is not charging?
My device is not charging as it is not showing the light?
좋은 질문입니까?
@avantikvardhan start with a new battery. If that does not charge then check your charger, your charging cable and finally the charging port. Make sure there is not dirt or debris in it and that it doe not have any bend pins etc.
After that you will need disassemble your camera and trace the charging connector to the appropriate boards and see if these connect to the battery. Let us know what you find out.
이 답변이 도움이 되었나요?
지난 24시간: 1
지난 7일: 6
지난 30일: 21
전체 시간: 120
