주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
250GB HDD와 Wi-Fi가 내장된 클래식 Xbox 360의 슬림 버전입니다. 수리를 위해서는 정교한 지레질과 특수 도구가 필요합니다.
Random freezing, restarting by itself
My xbox is freezing during gameplay, mainly at the first loading screen I come across, rarely at the dashboard and I have to unplug the power cord to shut it off. Sometimes the wifi card isn't detected as well. I can play Rainbow Six Vegas 2 for 10 minutes before it abruptly shuts on and off by itself.
I've tried cleaning and repasting it, didn't work and I can confirm temps are low. I've also reinstalled the latest update.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi!
Did you also tried to replace the HDD?
I would do that first and install the software again.
Guide: Xbox 360 S 하드 드라이브 교체
If it's still failing, try to replace the Wifi card and see if that solves anything.
Guide: Xbox 360 S Wi-Fi 보드 교체
I would try a new HDD first, you have some cheap ones at AliExpress and they do work fine.
Can you let us know how that goes?
Thanks!
Xbox 360 S 하드 드라이브 이미지
안내서
난이도:
매우 쉬움
1 - 5 minutes
Xbox 360 S Wi-Fi 보드 이미지
안내서
난이도:
조정
5 minutes
이 답변이 도움이 되었나요?
점수 1
댓글 4개:
I've tried removing the HDD before and it didn't do anything, I can run it without the wifi card and I still get the same issues so isn't that.
If all the above didn’t worked, same for the HDD, then you most likely have motherboard issues. Most likely the internal memory on it.. I recommend to replace that. It won’t be easy as soldering is required. You can replace the motherboard but this will be expensive.
@dan0 I have the Trinity model so was able to remove the 4gb internal memory, which fixed freezing during loading screens. The games now just freeze later on. The dashboard also wont respond to my input at times, but I'm able to open the smaller menu with the xbox button which does work.
Okay! That’s a good thing!!
Please replace it for a new one and install it completely as new.
Does thet work?
Thanks!
댓글 달기
답변을 추가하세요
MangosteenJuice 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 6
지난 30일: 19
전체 시간: 164
