주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
4세대 Jeep Grand Cherokee는 2011년에 출시되었습니다. 이 모델은 Jeep WK2로도 알려져 있습니다.
How to fix check engine
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
@adamahmed2582 you can't fix it for as long as you do not know what is broken. There are many reasons why the check engine light turned on. For the Jeep WK2 the check engine light is being controlled by the Powertrain Control Module (PCM). Anytime it detects a fault from one of the many sensors that creates a code that starts with "P" (Powertrain) followed by a 0 (Generic) or 1 (Manufacturer Specific) it can turn the Check Engine light on.
You will need to get the OBDII scanned to find out which error codes your engine has. Then use those codes to determine what needs to be fixed. Of course, once you have it scanned, come back here, let us know what those error codes are and we will do our best to help you with that.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Adam Ahmed 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 28
전체 시간: 117
