주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Why won’t the engine start?
Im having trouble getting my Cub Cadet LT1018 to start.
It used to be that the engine cranked slowly but would fire up...but if it didnt start fairly quickly I would have to charge the battery.
However, for the last week when I try to start the mower it just clicks. The digital meter on the dash was reading 9.5 when I would turn the key. Now the meter on the dash just kind of fades to nothing.
My voltage meter is reading that the battery is fully charged and good. The solenoid is clicking...I checked it with a circuit tester and both sides of solenoid light up when key is turned. The positive wire into starter also lights up when I check it with circuit tester and key on.
I‘m certainly no small engine repairman. Anyone able to provide me with some guidance? Is it possible the starter is bad?
Thanks
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Sounds like a bad battery. If you have a portable jump starter, or jumper cables from a car, give it a crank, if it starts, it's a bad battery.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Josh Wilson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 21
전체 시간: 144
