주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Renault Clio 자동차의 2세대 모델입니다. 1998년에 출시되었습니다.
Computer box not recieving 12v
My clio 2 has lost power on coil connectors now it doesnt start its just quite
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 9개
Hi @bonganisib42530
Does the engine crank when you turn on the ignition key?
Have you checked that the battery is OK?
의 공유
It used to crank before i thought its the crank sensor but only to find out after diagnosing it had a code that reads +after relay supply
의 공유
@bonganisib42530
Did you check if relay #1 Ignition main circuits relay 1 in the instrument panel fuse box is operating (click sound) when the ignition key is turned to start.
Also check relays #5 Starter motor relay, #9 Ignition main circuits relay 2, fuses F13, F14, F18, F22 & F24 in the engine bay fuse box are all OK.
All the above need to be OK when cranking and having the engine turn on
의 공유
I dont know which relay is the ignition relay there are 3 of the brown ones 20A then there are 2 pink 40A then purple 50A but all the fuses are ok i once tested a bridge that i think is the ignition relay and it blew the ignition fuse thats maybe when i started realizing that it may be the ignition relay
의 공유
@bonganisib42530
Here's a link to the fuse box diagrams for the 2006-2012 Clio models (you didn't say which year your vehicle is) that shows the location of the relays and fuses in the 3 fuse boxes i.e. main fuses box and power supply box in engine compartment and fuse box in instrument panel in the passenger compartment.
의 공유
댓글 4개 더보기
댓글 달기
답변 1개
선택된 해법
Hi @bonganisib42530
Here are the wiring diagrams for a Clio II, that might help. Hopefully they are applicable to your model
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Thanks i see the diagrams
의 공유
댓글 달기
답변을 추가하세요
bongani sibanyoni 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 38
전체 시간: 208
