T how do I fix it?
The freezer is coming on but it is not freezing
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 3개:
Locate the coils and clean them first; sometimes, if dust or debris gets on them, they can't dissipate heat efficiently. Also, is the fan spinning at all, or do you feel the cold air moving around the machine?
의
Hi @alvinmayers,
Does the compressor feel warm/hot to the touch?
What is the actual temperature inside the freezer compartment?
의
@somerandomguy_1
There is no fan inside the freezer and the evaporator coils are in the walls of the freezer cabinet i.e. static cooling method is used. This method is commonly used in chest freezers
Cheers
의
댓글 달기
