주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell OptiPlex 360은 실용적인 기능을 갖춘 비용 효율적인 데스크톱 솔루션으로, 비즈니스에 필수적인 가치를 제공하는 데 중점을 둡니다.
Sound is not coming
Sound is not hearing by us and not audible
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Is there any audio built in? if not its possible that you need speakers or a screen that has speakers built in before you get any sound.
의
댓글 달기
답변 1개
가장 유용한 답변
@muhammadra94899 you are not telling us what you have already tried and what you have already checked. You are also not telling us what OS you are using. I assume some Windows version.
First, you want to make sure that your onboard audio is enabled. Restart the computer and tap F2 to enter BIOS. Scroll to "Integrated Devices" or "Onboard Devices". Make sure that Sound or Audio is set to Enabled. The save and exit.
Next, check your Windows Audio settings. Click the speaker icon in the bottom-right corner and select the correct playback device (e.g., "Speakers/Headphones" or your monitor name. whichever device you are using to receive Audio). Next check to make sure the volume is turned up and that is not muted.
After that, you want to update your audio driver. Go to the Dell Drivers & Downloads page.Select your operating system (e.g., Windows 7/10).Download and install the Audio Driver (usually Analog Devices/ADI).
Of course, make sure that you have speakers connected and that those are working as well.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Muhammad Ramzan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 19
전체 시간: 148
