주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola Edge 20은 모델 번호 XT2143-1로도 식별되며, 2021년 8월에 Motorola의 가장 얇은 5G 스마트폰으로 출시되었습니다.
Touch is not working
The screen is working when I connected a mouse to it, otherwise the touch is not working
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
@khattboyss32990 this very much sounds like a failed digitizer. As you probably already know, that is part of the display assembly. I would start of with replacing that. If a new display does not resolve this, then the issue will be on your circuit board. Could be a bad Touch IC or some other related component. For that you will need the schematic, the component placement file as well as the right tools and skills to diagnose component failure.
SInce iFixit does not yet have a specific guide for this, use something like this video for that repair. You can also download the service manual from here Motorola Edge 20 under the Documents header
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same issues with their device. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Where can I get the original display?
의 공유
@khattboyss32990 does not look like iFixit has those yet. You can most likely get an original screen only from Motorola. You would need to try a display from some other vendor to make sure that it works.
의 공유
댓글 달기
답변을 추가하세요
Khatt.boys.school.c2c3 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 38
전체 시간: 175
