주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
수냉식 Porsche 911의 1세대인 996 시리즈에 대한 수리 안내서와 지원 정보를 제공합니다.
How to change engine
How to replace the engine
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
Replacing engines requires a lot of tools and test equipment. Best to find a local mechanic do the job. Your choice of engine is mostly limited to what the vehicle came with.
Are you sure the engine is shot? Rebuilding is often done not replacing.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
@inbankuppan not as easy as the pages for the Porsche 996 Engine Removalfrom the FSM make it sound like but definitely doable. Working on a Porsche is not quite rocket science but it does have some tight fits and requires special tools. Besides that, it's just as straightforward as any other performance vehicle.
Just in case yours is a GT3 use the Porsche 996 GT3 Engine Removal since it is a bit different.
Here is the List for the Porsche 996 Engine Part Numbers of replacement engines, you will need to match your model on this page for a replacement. BTW, as you probably already know, those are not inexpensive ;-)
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Inban Kuppan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 12
지난 30일: 45
전체 시간: 208
