주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PS4 컨트롤러 모델 CUH-ZCT1. 소니 컴퓨터 엔터테인먼트에서 2013년 11월에 출시한 이 6축 3.7V 리튬 이온 배터리 컨트롤러 수리는 복잡하지 않습니다. (참고: 해체 안내서는 이 모델용이 아닙니다.)
Am I soldering correctly?
This more of a general question I feel like I'm soldering at a too high temperature I keep damaging the mask around the vias sometimes stripping the mask around the vias revealing the copper I don't know if that compromises the connection or not at what temperature I should solder at? I currently solder at 400c I use both lead and lead free solder.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Hi @christophe89153
Sounds like you're applying too much heat. Either that or you're applying it for too long.
Are you "tinning" the via first, before soldering it to the board?
Tinning means coating the part of the wire that you wish to solder with a thin layer of solder. Easiest way is to melt some solder on the tip of the soldering iron and then pass the part of the wire that you wish to solder through the molten blob of solder so that it gets a thin coating of solder. Then when you go to solder the wire to the board you only need a minimum amount of soldering time for it to solder onto the board.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
In my previous attempts I wasn't thinning the vias, but I was using flux. I have started to thin with low melt solder and got better results. I have 90w solder iron station and it can easily melts the low melt solder at 200c
댓글 달기
Can you give a picture of what you are trying to solder? What type and wattage is the soldering iron you are using? 70W-90W will take care of most circuit board soldering. 320C -350C is probably better for small components. You are likely too hot.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
I have a 90w solder station I'm soldering anything from batteries for cartridge games that use one to analog sticks for controllers
@christophe89153 That should work with a good clean tip (small chisel type) . I think your temp was a bit high. Much higher than I ever use.
댓글 달기
답변을 추가하세요
Christopher D 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 27
전체 시간: 133
