How I can replace transmission oil
How I can check transmission oil level
좋은 질문입니까?
@mandeepmaan here are the Atfinstructions for the Ford PowerShift DPS6/6DCT250 which is one of the transmissions used in your Fiesta. Essentially, you open the drain plug to drain the ATF (on a warm transmission only) and use the filler plug to add ATF. You will need to fill until it starts to leak back out of the filler plug.
이 답변이 도움이 되었나요?
지난 24시간: 2
지난 7일: 17
지난 30일: 123
전체 시간: 572
@mandeepmaan what exact year and model is your Fiesta and I assume you are referring to an Automatic Transmission?
oldturkey03 의
