주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple M1 칩을 탑재한 2020년형 Mac mini의 수리 안내서, 분해 정보 및 문제해결 정보. 모델 번호 A2348로 식별할 수 있습니다.
Mac Mini power plug
Is there some way to stop the power plug from disconnecting from the Mac Mini so easily? Even the slightest shift in the positioning of my Mac, and the power plug falls out. Extremely annoying!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개:
What is your exact model as Apple has a few different setups. Click on the system icon on the right to see the different series.
의 공유
@danj It's the Apple Silicon M1.
의 공유
댓글 달기
답변 1개
First off, here's the Apple supplied Mac mini (M1, 2020) Repair Manual
This series uses a standard IEC power cord, here's Apples P/N 923-00645 which you can order but there are cheaper options locally to you. I would try that first.
If a different cord didn't help, then sadly The whole power supply will need to be replaced as the socket is part with it. Here's that P/N 661-16789
Both can be ordered from here Self Service Repair Store for Apple Products
Here's the section which goes into replacing the power supply Mac mini (M1, 2020) Power Supply there's a few steps before the guide will aim you to what's needed.
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
I don't need to replace the power cable, I just want to know if there's a way to stop it from coming out of the socket so easily. I know that they're designed to release if the computer is knocked over to protect the pins, but mine will pop out if I move the computer even a centimetre or two! It's extremely annoying!
의 공유
@suegarnhum - Yes I got that!
The cord and socket have friction to hold the cord from popping out. Over time this friction loosens! The cords contact clips can also loosen up so the cord may appear to hold fast the contacts aren't making good contact. The cord is often the failure!
Really, the answer is try a new power cord then you'll need replace the socket which here it's part of the power supply.
의 공유
Ahhh, now I understand! Thanks for clarifying that for me.
의 공유
댓글 달기
답변을 추가하세요
Sue Garnhum 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 49
전체 시간: 217
