주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Optiplex 790 수리 안내서
Why power button blink orange light
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Hi @abdulhadi96018
Check which diagnostic LED lights 1-4 on the back of the computer are on as they will tell you what the problem is.
Go to p.73→p.75 in the owner manual to see all the combinations and what to do.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
An orange light typically indicates a power delivery issue or an internal hardware failure preventing the system from starting. Unplug everything (including the power cable) from the computer and press and hold the power button for around 20 seconds until the pc drains of power. Then, plug only the power cable in and see if that fixes it. If it doesn't, then you can try to see if your PSU is the issue. Locate the small button and LED light next to the power cord inlet on the back of the computer. Press the button. If the LED is solid green, your power supply is perfectly fine. If it remains unlit, or it blinks, your PSU is at fault, and you should replace it.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
PSU is perfect but still orange light
댓글 달기
답변을 추가하세요
Abdulhadi 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 25
지난 30일: 71
전체 시간: 434
