주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
1998년 11월에 출시되었으며, 모델 번호 HKT-3020으로 식별됩니다.
What is going on here?
Hi, I recently install the retro gem for my Dreamcast and when I boot the system it doesn't show the boot animation for the system only when its completed I went to debug menu and have hearts on all my installs as well as updated the firmware. I tried this on two TVs and it does the same thing. I have a Gamecube with a plug-in mini-HD to HD and it does something similar I used the same cable from that.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 8개
Hi!
Is it possible to upload some pictures regarding the issue you are facing?
기존 질문에 이미지 추가하기
Thank you.
의
Can I upload video? pictures won't help
의
Yes you can!
Using Media
Thank you
의
Hi, I upload the videos in the first video it's the gamecube with the hdmi plug-in, the second one is the gamecube with S-video, and the third one is the dreamcast with the mini-HD to HD. I used the mini-HD to HD from the plug-in I couldn't get the av footage for the dreamcast cause I think I messed something up ....again, but it does the same thing as the gamecube plug-in. I hope its just the mini-HD to HD cable that's causing this. It's the basic edition of pixelfx mod
의
Okay, replacing the cable you can try indeed. It does not really look like a hardware issue in the first 2 pictures. More firmware related. Which firmware has been installed? Thanks!
의
댓글 3개 더보기
댓글 달기
답변 1개
선택된 해법
@dan0 Hi, I went on the retro gem discord and I was told that the delay in video is normal because the retro gem is booting.
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
Alright. Then it is normal behaviour. Thanks for sharing!
의
Sorry for the delay thank you
의
No problem at all! Have a great day :)!
의
댓글 달기
답변을 추가하세요
Christopher D 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 20
전체 시간: 183
